Note: you can do this with pretty much any Dragon, though for Flame you will need to tweak it a bit. Merely a planned build at the moment, as i don't actually have a Dragon (yet, want dynamic weapons first, if Dragons ever get the overhaul...). Build around XL360, because i have one, and such insane speed for a heavy is simply too appealing to pass up, and given the limited weapons there isn't much use for the weight otherwise. This is effectively a sniper so choose modules accordingly. The SRM6 exist to eat the extra tonnage and to provide some close range punch. SRM4 might be better, the extra ton could be used for extra ammo, extra heat sink, or whatever you can think off. Or you might not need it at all. Note on armor: I have kind of arranged it as it likely would be in the Battletech boardgame if this where used in it. Feel free to tweak it naturally, moving a couple of points to the CT may be a good idea, though 2 points either way isn't going to matter much, i think.
