The Concept comes from my experiments on the JM6-S. I quickly came to the idea, that the CTF-4X can fit this loadout as well, BUT with the difference, that you can run it with a Standard Engine instead the fragile XL. It has enough Ammo to break 1K and can also go Zombie with a LLas!!! It's a very simple Loadout, you just have 2 or 3 Weapongroups: 1. AC15 2. LLas 3. AC5s (Chainfire) Alternate "ER" Version: Alternate "XL + Ultra Ammo" Version: Alternate "XL + SRM" Version: Blagg p.s. can also be transferred to the IM, where you can run it with the XL300 if you wish the Speedboost.
Heat definitely won't be a problem on this build, so ER all the way! Zombiability is a nice feature. Unfortunately the laser position is quite low.
not that i have anything against simplicity, but wouldn't it be better to have your weapons grouped as to which side they are on? especially with a knuckle drager such as this.
