Before you go NO XL AND GAUSS IN A PHRACT check this out. Anywho onto the build You can set this up two ways one with the XL or one with a standard 275 that has less firepower but more survivability. The build has CW feel written all over it and it performs well even in my meh-skill hands.
I do wanna to give this a try, quick question - how do you find the Stealth Armour variant, is it useful?
While you can do some funny (and dangerous) shenanigans and will get to shoot first a lot of times, in the end the cataphract is too slow and bulky to boldly sneak around but on the other hand, as long as your build can spare the slots and the weight there is no reason not to use it. After all, "Our biggest weapon is surprise!" Now go and sit in the comfy chair... ! EDIT: That's what I use
5/5, Sniper CTF working as intended. Positioning so you can peek above hills seems the best. Quirks make the ERLLs 900m+ and it's very cool also. You can setup on wide flanks and ECM will have you covered. Build code under with TC3 3,5t ammo. Spoiler: Build code Ag4820B1|i^|Kdpf0|m?|HO|HOqf0|^<2|eO|i^|1=2r\0|]?s\0|]?|]?tT0uT0v@0|HOw606060 Highest damage played: 1110 Did figure out with the quirks it's possible to fit 4xERLL with the Gauss, XL255 and 1.3 in Heat Spoiler: Build Code Ag4820B1|Edpf0|m?|HO|HOqf0|^<2|i^|i^|eOr\0|]?|]?s\0|]?|]?tU0uU0v>0|HOw606060
