After being dissatisfied with AC20+6ML i decided to make use of missile hardpoints. And I ended up with this marvel. It is very tanky, brutal and super heat-efficient. It has what everybody wants (except long-range weaponry) - speed is sufficient to close the distance, AC20+2SRM6 provide a solid close range punch and 3MPL allow us to finish enemies with precision. MPLs located in hand provide us with ability to take down pesky UAVs and one SRM6 located in CT give us a zombie capability. Something tasty for everyone. Here is the skill tree setup I use: https://kitlaan.gitlab.io/mwoskill/?p=5028ff8e-6cd4-11e7-a38a-bd68b0e9cc05&s=Sensor Systems It focuses on firepower and toughness. I also put some points into operations for heat-efficiency and whats left into sensors with one node being quite important - the often ignored target retention. I found myself losing target info after shielding (when I lose LoS of enemy) or when light mech is running around (not for long before he regrets it), therefore I found this useful. I use standard for myself weapon groups: 1) 1xAC20 2) 3xMPL 3) 2xSRM6 4) 1xAC20+2xSRM6 5) 3xMPL /chainfire The first three are for each weapon individually, forth is for the punch (most heat-efficient and well synced with the same cooldowns) and fifth is rarely used but can be big in those 95% heat, all structure red situations. The build was tested also after civil war era and it works wonderful as it is and I cannot come with any improvmentes using LFE or other new tech. Also one thing - MPLs are located on the opposite site to the AC20 for a reason. Often enemies aim for your right torso, so after its gone you would be left almost weaponless. However with this configuration no matter whether torso enemy will take down, you will always have a decent firepower - either AC20 + SRM6 or 2xSRM6 + 3xMPL - so that's the way to go. Only thing you can change is adding AC20 ammo instead of case. The rest should remain the same if you want to be the king of the battlefield. That's it. Try this mech and you will fall in love!
