    -- the MechSpecs team.
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Discussion in 'Game Guides and Tutorials' started by Excalibaard, Jan 17, 2018.
GUIDE Compact Equipment and Utility Weapons guide
A rundown of equipment available in MWO and when to use them effectively.
  1. Excalibaard
    Excalibaard 01110010 01101111 01101111 01110100 Staff Member
    3,884
    769
    219
    Excalibaard submitted a new resource:
    Compact Equipment and Utility Weapons guide - A rundown of equipment available in MWO and when to use them effectively.
    Read more about this resource...
  2. Remover of Obstacles
    Remover of Obstacles Benefactor
    800
    297
    69
    Excellent guide.
    How many times have you heard someone say that they are using a Targeting Computer to help their missile boat build?
    Could you flush out Stealth armor by adding what counters Stealth Armor and what does not?
    For example which of the following actually stops Stealth Armor:
    Narc, UAV, PPC hit, Tag, Active Probe, ECM in counter, Flamer, etc.
  3. Excalibaard
    3,884
    769
    219
    Too often.
    Haven't run much with stealth armor, will have to do some testing. I THINK it's all of the above, except flamers and maybe active probe :)
  4. Shock
    Shock Benefactor
    600
    246
    53
    A couple things you could add:
    Clan mechs have CASE in all components by default at no cost
    NARC will cancel the target's ECM but it can still be countered by another ECM in range.
  5. Ruludos
    Ruludos Benefactor
    88
    50
    Flamers are a decent soft counter to stealth armor, though, because it'll force them to turn it off much more quickly than normal.
  6. Excalibaard
    3,884
    769
    219
    Your suggestions have been added! Thanks!
  7. Remover of Obstacles
    800
    297
    69
    Re: Stealth armor
    Still detectable to seismic.
    When Stealth Armor is active, you do not get enemy target information.
  8. CarloArmato
    CarloArmato MechSpecs Addict
    777
    214
    49
    Re: Stealth armor
    Stealth armor rely on a working ECM in "disrupt" mode. If the ECM get countered by any Active Probe, you can't activate stealth untill it is no more countered. I'm pretty sure (but NOT completely) that if you are already in stealth mode and an enemy mech fitted with any AP get close to you, stealth won't be deactivated.
    Also, Tags and NARCs works versus a stealthed target, but I'm pretty sure UAVs don't. This also applies to other "fixed spotters" like turrets and "escort mode radars": they won't spot you and even shoot you as long as stealth mode is activated.
    It is possible to get target info, but only below a very short range (270 meters or even less)
  9. Ruludos
    Ruludos Benefactor
    88
    50
    Do you think it’s worth talking about L/AMS in the guide?
  10. Excalibaard
    3,884
    769
    219
    Considered it, but AMS at least does what it says it does (as in: it's easier to understand that an Anti Missile System is against Missiles, than that a Targeting Computer does not help with targeting.)
  11. Purity The Kitty
    Purity The Kitty Active Member
    83
    Just to comment: ATMs are _not_ pre-equipped with Artemis. If you switch your mech's targeting system to Artemis, you will gain the 50% faster lock time. As far as I can tell it will not affect ATM spread.
  12. Excalibaard
    3,884
    769
    219
    As far as I've experienced, as long as ATMs (and other Artemis weapons) are the only weapons equipped on the mech, you get the 50% lock time reduction inherently. That would also make sense with how weapons work in lore. In previous patches, SSRMs used to get a lock time bonus from artemis on accident, that functionality has been removed since. It'd be very weird in the least if PGI made the exact same mistake they patched out after months of complaints with the new ATM weapons.
  13. Purity The Kitty
    83
    I tested it last night on my Shadow Cat equipped with an ERPPC, ATM9, and 6 machine guns. My ATM lock speed was increased by 50% when I bought Artemis guidance. This also worked with clan streaks.
    As PGI has said before, the Artemis bug cannot be fixed because it is tied to how launchers work, and that they are all a single weapon type.
  14. Excalibaard
    3,884
    769
    219
    I'll try some tests as well and update accordingly. Thanks for bringing this to my attention, I thought they fixed this bug years ago.
  15. Excalibaard
    3,884
    769
    219
    Excalibaard updated Compact Equipment and Utility Weapons guide with a new update entry:
    Artemis edited!
    Read the rest of this update entry...
