    -- the MechSpecs team.
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Cipher 'Tank-Buster' (6xcuPL, 6xcMG, cXL180)
1 rating
Discussion in 'Cipher' started by Aylek, Mar 30, 2018.
  1. Aylek
    2,739
    505
    High dps build on the Cipher. Playing this thing differs a lot from the mass MG PIR-1, but it's deadly nonetheless.
  2. Dagonus
    Dagonus Benefactor
    Your title says LMG and your build shows MG. Which are you suggesting?
  3. CarloArmato
    CarloArmato MechSpecs Addict
    760
    "High DPS" with micro pulse lasers... He probably mispelled standard MGs.
  4. Aylek
    2,739
    505
    Yeah, it's standard MGs obviously. Sorry for the mistake. LMGs are trash. ;-)
  5. Aylek
    2,739
    505
    Working on it...
  6. CarloArmato
    760
    The way to go on the Cipher: I personally strip some armor and add a 7th cuPL, but that's me.
  7. PeterCarpetBeater
    PeterCarpetBeater New Member
    Why not run with 8 Micro Pulse Lasers? The ghost heat starts at 9. I personally had some devastating results with this build.
    Check this clip:
  8. Aylek
    2,739
    505
    Simple reasons for exactly the 6 / 6 setup: from my experience with this chassis I wanted both every single bit of armor, even on the arms (which surprisimgly work as shield) and a sufficient amount of MG ammo.
