Even simpler and user friendly version of CHP-3N "Apprentice" (1xGR, 6xERML, LE280) + alt for those who do not like gauss charge time Apply the same pros from the previous thread, with even more speed and cooling effiency. The Cons are a loss of a poke weapon at long ranges (AC10 instead of gauss), worse projectile speed which means worse synergy with lasers, and finally loss of shield arms (said rookie probably won't use them anyway) but it should be a solid build overall. ALT: LE295 with LPL instead of LL, so build will feel like half vomit laser, half dakka ALT: LE280 with TC1 and a RL10 mini panic button
I feel like it might be a little too heat efficient - but I'm still figuring things out with the recent changes to how heat works. I'd drop a couple heat sinks, change the LL to a LPL like you did in the second build, and upgrade to Ferro for a tad more armor.
