CGR-1A1 "Hyper Laser" (7ersl tc8 LE380)
1 rating
Thread in 'CGR-1A1' started by Galahad2030, May 6, 2022.
  1. Galahad2030
    Galahad2030 Junior Member
    46
  2. Galahad2030
    46
    With new speed tweaks you now reach 88kph.
  3. Ether Dragan
    Ether Dragan Well-Known Member
    Very nice build. With the last patch, SL have -65% Cooldown & +65%Rang.
    I propose my version using ERSL with a crazy heat management. If you want to play with regulare smal laser, I recommane to play this version.
    Maximum engine for maximum speed (95.2 Km/h)
    Standard Heat Sinks to completly forget any heat management issues
    Beagle active prob plus Tageting computer for maximum perception
    Laser AMS, because it will never stop working
    This mech is completly unique and crazy, I love it!
    cgr-1a1s
  4. Ether Dragan
    Some tips for this particular build
    Consult the previous tips post from "Small Hyper Turbo Rays Ultra" before, I will add some complement below.
    Laser AC 3.75
    With this build, I use a pack of 7 Extended Range Small Lasers. The Quirks give this weapon a unique profile. It has a range of 385m it deal a little 26.25 dmg with a complete firing cycle every 1.49 seconds.
    Forget how you use lasers; the rate of fire, heat management, and range make this weapon like an AC 3.75 (referring to the damage of Small Lasers). So, these mini "autocannon" trade Pin Point Damage for a short Hit Scan of 0.64 seconds but eliminate velocity issues in favor of an Instant Hit. Moreover, this AC 3.75 has infinite ammunition.
    The range difference between the SL and the ERSL must be exploited. Going from 305m to 385m might not seem like a big difference, but it is significant. Staying within the optimum range just under 400m protects you from most of the arsenals used by Brawlers. MRMs will never hit you, an IS AC20 (like an IS ML) will do much less damage and will have a hard time hitting a Mech moving at 95Km/h at that distance. Similarly, the low velocity of MRMs can be dodged.
    It is important to exploit this range of 350/400m as much as possible with this Mech. Indeed, the ERSL generates significantly more heat than the classic SLs. 1.9 heat for an ER SL compared to 1.1 for the SLs. Firing all 7 simultaneously in alpha strike, we get 7.7 versus 13.3.
    So, that's 5.6 more points of residual heat to dissipate after each volley. As you can understand, use the mobility of this Mech to maintain this distance range as often and as long as possible.
    Moreover, unlike what is done with an Energy or Dakka build, any opportunistic shot below 700m is worth taking; you won't have an ammunition problem and only occasionally a heat issue. Don’t hesitate to use your strong heat capacity; your 14 tons of Heat Sinks (17 if you replace the Laser AMS and the BAP) are there for a reason.
    Enjoy yourself, open fire continuously as soon as a target presents itself.
    That's all for this build with 3.5 tons of armament on 80 tons of Mech.
  5. Ether Dragan
  6. Ether Dragan
    Version with Double Heat Sinks, LE400 and Small Laser (Not ER).
    Can perform 59 Alfa before Overheating with no skills.
    cgr-1a1
