With "only" an LE350 this mech is slow for a charger, but saving weight on the engine allows to add 2 Heavy PPCs and 5 small lasers that benefit from the outrageous quirks on this mech. The combo gives you a 30 pin point punch at around 600m plus some little daggers at 250m. If you can avoid the 80m minimum range and engage with both you really can tear things apart. Add some LAMS or a maybe a TC1 or 2 for garnish and your off to the races! Its a bit slow at 81kph with Speed Tweak plenty enough to get the job done! https://mwo.nav-alpha.com/mechlab?b=84c3d0e8_CGR-1A1
