CDA-2A Laserbug MKIII (3x LLas, XL280)
Thread in 'CDA-2A' started by Blagg Zear, Sep 28, 2013.
  1. Blagg Zear
    I don't use this build, but i saw it on someones Cicada and he killed a lot in a match, so I post it. It's slow but has the Firepower.
    Blagg
  2. Kryten 2X4B
    Kryten 2X4B Active Member
    I am using this build to grind up some xp, but its more fun than i thought :)
    When you need, dont be shy to take some ghost heat, on one alpha or two you can easily leg enemy mechs running towards you, mostly it depends on how dumb your enemy is, skilled players will send you to the garage in a minute:)
    Could not get better map for my 5th match with cicadas (Alpine peaks)
    some crazy alt waiting for test:
    [img width=700 height=116]http://s25.postimg.org/yf176eejz/720x120_kryten_2x4b.jpg[/img]
