Casual BSW-P1 "kiTARADO3" (6xLRM5 1xRAC2 1xML XL280)
Thread in 'BSW-P1' started by Alloh_BR, Dec 7, 2018.
  1. Alloh_BR
    Alloh_BR Junior Member
    45
    I started from "kintaro2", 6xLRM5 and TAG. bUT None of my mechs is ammo-only.
    So I got back to mechlab, and present you the most FUN build I've found for Bushie P1:
    BSW-P1 "kiTARADO3" 6xLRM5 (4t) RAC2 (1.5t) ML XL280
    Avoid using both the missiles (allways chainfire) and ML/RAC2. Can be used for short time. But usually I'm either shooting missiles far away OR I'm RAC'n and Lasering someone nearby.
    I'm often running out of LRM, then I rush forward until I'm out of RAC2s... still a ML to use! So I tried replacing the DHS for +1 LRM ammo, but gets too only even only using missiles.
    If you want more ammo, replace the RAC2 with AC5, LB5x or (u)AC2, but you'll lose a lot of firepower and the impact of a RAC...
    And it's always fun see a light rushing towards me expecting a full larmer, and ML+RAC starts pounding...
    Of course ammo placement is for clarity, near its weapon. Adjust properly.
  2. Excalibaard
    4,300
    936
    219
    Modified your title to the standard
    This build looks positively annoying for both parties :)
