Here's an little build that I put together for general use. the only thing you have to look out for is a tiny bit of overheating if you fire all the lasers together 4-5 times without a brief pause. (Like, say if you need a moment to get back on target.) _ This build is great if you are good at positioning yourself just behind another mech, and within a range of about 80-250m. My most recent game results.
Quick synergy improvement: ERuL and SPL have very similar range / duration / cooldown, plus they have different heat scale groups, so you can safely boat 6xSPL plus how many micro lasers you can (up to 10, if I remember correctly) Don't worry about head and legs: head can still resist a dual gauss hit, while your legs will rarely be focused by other players. _
Thanks for the improvement, that 59.9 was messing with my head for a while. Also, any tips on how to get the fancy window? I couldn't figure it out on my own.
You are welcome. About the embedded window, you need to click on the media icon (the one with the "film strip") and then paste your link. Code: Original link: https://www.mech.nav-alpha.com/#7b7ab7ca_MDD-RV [MEDIA=mechdb]7b7ab7ca_MDD-RV[/MEDIA]
