I had been trying for days to get a build for this mech that I enjoyed playing (finally got the basics done) but didn't really like anything that I was driving. Been building everything around an AC20 since it only has one ballistic, and I'm not really that good using a Gauss. This has been so much fun & very easy to shoot. Weapon Groups 1. ER LL(x2) & Gauss 2. Gauss 3. ML(x4) I shoot the large lasers and just hold the button down... when the lasers stop firing I release the trigger which fires the gauss. Its so simple and easy even I can't mess it up. The ML are for added damage and while its a very cool running mech but it can still heat up on the hotter maps (staring at you with hate in my heart Therma) in full firing so I just use the gauss by itself then... Nathan
C.A.S.E. because you have a Gauss next to your engine. Gauss ammo with the weapon for crit padding. Armor values improved. All weapon slots used.
Case is pointless because Gauss ammo is not explosive, the Gauss Rifle itself is but not enough to blow out the side torso and travel over into the center torso. Using a ML in the arm slot is not a whole lot more damage but does heat the mech up unnecessarily during sustained firing. only very rarely have I encountered people intentionally trying to leg an assault.... there's a ton of armor there to get 10 more shots with. Lets you be more free with your shots, cause I almost always burn through 40+ rounds in a full match I survive. Nathan
