BLR-1G This is a basic setup that works for me very well. I almost always do over 500 damage, and have hit 1000 a few times with it. Heat isn't much of an issue except on very hot maps. To make room for ammo, double heat sinks and what-not I opted for endo-steel, which does make it a bit costly. AC5 and PPC give good damage at range, and while not flashy, 6 medium lasers are deadly in a brawl. I usually make quick work of Dire Wolves and Atlases with this setup.
Greetings, @kjtaylor70 and welcome to Mechspecs. I would like to refer you to this post about naming your build threads: https://www.mechspecs.com/faq/how-do-i-title-the-subject-of-my-builds-on-mechspecs.8/ I've fixed this one for you, but keep in mind that further threads created without the proper naming rules can and may be deleted. And none of us want that to happen. Also, be sure to post the correct build in your thread, as the link you provided above simply shows the stock loadout on the 'Mech. And please refer to this post for how to properly link a Smurfy build here on Mechspecs: https://www.mechspecs.com/faq/how-do-i-post-a-smurfy-code-on-mechspecs.5/ Good luck, and enjoy your time here.
