I was finding that those juicy eye-level energy points are wasted on medium lasers. Also, clearing that right arm to keep shots out of the dirt was creating way too much exposure time. Power up hill, slam reverse just before you crest, fire PPCs (and ML if possible), pivot left as you back out. Due to the way I generally play, it doubled my scores from trying the brawler builds - this seemed to suit me better. It is actually cooler than it looks, as you will only use the ML inside of 90m or against fast movers. Good synergy with the PPCs and dual 5's - Similar ranges and projectile speeds. XL? Well, what can I say. Try not to get into an extended turning fight or side-peeking and it seems to work ok. I found it didn't matter much, as I was getting CT cored mostly anyway.
