Casual Bellonarius "Blackhawk" (1xSRM6+A, 2xMPL, 6xcLMG, OMNI)
Thread in 'Bellonarius Builds' started by Dagonus, Feb 21, 2018.
  1. Dagonus
    453
    My first pass on These mechs ran with Omnis because. I have run this once so far with limited success, but it should play something like a heavier Viper with the MGs.
  2. Falconium
    Interesting concept for a high-DPS brawler. With the speed on these things, it could definitely work quite well.
    Here's a redesign with some minor tweaks. Dropped the Artemis, went with 2 SRM4 instead of a single SRM6, and picked up an extra half-ton of ammo with the exchange.
  3. Dagonus
    453
    So I had switched over to FaIc's version, but I've found that I wasn't really making use of the LMGs range, so I shortened them up to MGs. Then I decided to go a step forward an use ERSLs and 2SRM6As again.
    The result is a higher sustainable DPS and a bigger alpha to boot. The trade off was some range, but I wasn't really making use of that.
