Casual AWS-8V "Almost completely renewed" (3xMRM20, 2xLL, 1xERML, TC1, LE300)
Thread in 'AWS-8V' started by CarloArmato, Oct 10, 2018.
  1. CarloArmato
    Following the steps of "Almost completely old", but with MRMs for brawl and mid range engagements, with higher alpha strike in mind and exploiting the most those torso hardpoints.
    Plays quite similarly (soften up at range, finish off in a brawl) and has very similar sustained DPS, but is nowhere close to be completely heat stable with MRMs only, so don't push hard / start a brawl if you are hot.
    Don't forget the left side has a dead arm to soak up some damage.
    ALT: swap TC1 for 1 ton of ammo
