Invasion ASN-23 "Sassy" (3xSRM6+A, 1xJJ, XL295) + alt
Thread in 'ASN-23' started by CarloArmato, Apr 16, 2018.
  1. CarloArmato
    1,192
    364
    165
    I'm really astonished nobody already published this build.
    Works in both scout (any map where brawl is expected) and invasion (preferably hot maps where speed is needed for cap / skirmish, e.g. a conquest match).
    Good speed, good ammo count, 10% SRM cooldown, good armor quirks, jump jet for quick turning / avoid fall damage / climb short steps, artemis upgrade for precise shots even at range. Don't hug the target: keep you range at 150-200 meters and exploit both torso yaw and artemis precision to pinpoint your damage and spread the incoming damage as much as you can. If you are facing a target with pinpoint weapons, do the opposite: circle the closest you can or break contact if it can track your movement.
    Skill wise, don't bother operations, go firepower (ammo and cooldown, heat gen is not mandatory but welcome, range is actually preferable), survival (most of armor nodes), mobility (at least 3 speed tweaks) and radar depravation.
    You will love this build.
    ALT: previous version with +1 DHS and lower engine
  2. Excalibaard
    4,271
    931
    219
    I've seen Needa_Pickle wrecking with this thing. I personally still prefer the ASN-21 with 4SRM4 but this is undeniably very good.
  3. Purity The Kitty
    Purity The Kitty Active Member
    83
    I think with the armor quirk nerf on the ASN-21 this might be better now.
  4. Dubious Squirrel
    Dubious Squirrel New Member
    Yep, this works nicely. I've been running the 21 with SRM4's but I thought I'd try this one out for the missile quirk. It's a close call but for me, this one has the edge.
