AS7-RS "Fine Touch" (1x Gauss, 2x LLas, 2x SRM6, 2x MLas, AMS, STD320)
1 rating
Thread in 'AS7-RS' started by The Verge, Oct 8, 2013.
  1. The Verge
    Modified to reflect my change in mech building.
    Weapon Groups
    1. 2x Large Lasers
    2. 2x Medium Lasers
    3. 2x SRM6's
    4. Gauss Rifle
  2. Blagg Zear
    :wtf: why do you use CASE for just a single ton of Ammo on the right side instead placing CASE and Ammos on one side (left) together?
    why don't you just drop CASE and put all Gauss Ammo to the GR (crit-padding) and all SRMs into legs?
    why don't you go for the STD325 for more Heatsinks in Engine? 15 DHS should this monster have for decent Cooling..
  3. The Verge
    To better answer your Question Blagg, here is a list
    -Gauss rifles Explode, causing damage to the torso installed and surounding parts. CASE prevents it from damaging my engine
    -Good point, Changes Made
    -DHS are padding, outside of the engine. Also, Still don't have that 325engine.
  4. mmstahlman
    mmstahlman Active Member
    84
    I think I found me a new RS build to play... Will rate after I play it.
  5. JustCallMeHero
    JustCallMeHero New Member
    I like it...
