AS7-RS "Blue Thunder" (4x LPL, STD325)
4/5,
1 rating
Thread in 'AS7-RS' started by Xiomburg, Nov 16, 2013.
  1. Xiomburg
    Xiomburg Dispossessed
    I love pulse lasers, especially the large ones. Thump, thump, thump. Thump, thump, thump.
    While the Large Pulse Lasers and have had in increase in heat, they have also had a slight bump in damage as well. Then with the ghost heat, makes Blue Thunder even harder to play.
    You can alpha strike with the 'Mech, once and it is no advised. But pairing them up and using them that way, you can sustain a good rate of fire with the 'mech.
    Coolshots...you will need both of them.
  2. The Verge
    at least use the ballistic slot. this is now serious mech business.
  3. Maurox
    Maurox Well-Known Member
    109
    It could use a bit more speed:
  4. dranozir
    Still good build !
