You have acceptable sustainability when using only the UAC10 and MRMs, and my recommendation is to lean more heavily on those weapons in a brawl. If you have heat to spare or you're just chilling and poking then you can use the ERMLs. Other than that? The only other situation you should use lasers is to finish off a component with pinpoint. Ammunition concerns? Take them to Duncan, he might care more than me. An Atlas shouldn't survive a match unless it's a stomp, anyway~
5/5, I think the UAC-10 goes well with the MRM range, allows a 80 point burst at upto 500m. However i prefer regular Mediums Lasers, with the Kraken range and cooldown quirks, the sustained DPS is awesome.
Thanks for the rate! You raise a good point with the quirks, plus the overall sustained DPS being higher is a nice touch. I'll give your version a whirl, see how I feel about it.
