Meme AS7-K "Pug kiter" (3xERLL, 1xGR, 2xAMS, TC8, LE350) + alts
4.5/5,
Thread in 'AS7-K' started by CarloArmato, Sep 26, 2018.
  1. CarloArmato
    Theory crafted. Use at your own risk.
    So those pesky LuRM boat voted for polar highlands? Worry no more: this mech is the long arm of the LAZORS-GAUSS meta and, if it was not for the damn low hardpoints, it could actually be a decent sniper. Anyway: extreme ERLL range once fully skilled (990 meters optimal range!), free-heat Gauss damage at mid-long ranges, dual AMS protection to further damp incoming damage.
    Actually it's probably best used in those med-long range maps where you mainly side poke, like grim plexus.
    Always stay the furthest away as possible, but NEVER be shy with this mech, otherwise you ain't gonna do anything and, according to VOIP, become a worthless long range assault scrub in no time.
    Build has been made considering a total -20% gauss cooldown, -10% energy cooldown, crazy armor quirks and +15% energy range, so you can actually stay in the open, fire like a madman and tank like your liver during saturday night, because this is the atlas your team needs, but not the Atlas this game deserves.
    ALT: AMS-less version in case you trust your positioning skills.
    ALT: previous TC4 iteration with better speed and cooling, pre-DHS buff patch
  2. Throet
    Throet Active Member
    Viability for Stated Gameplay Role: 5/5
    Troll Level: Over 9000
  3. Lorgot
    Lorgot Advanced Member
    403
    72
    If we’re going there, where going there fully
    Fight fire with fire, and get burnt a little bit
  4. CarloArmato
    TBH that was exactly my very first build (only ammo location was different) because I wanted to squeeze that juicy -20% missile cooldown too, but a single non-artemis LRM10 is not likely going to deal any meaningful damage for the final kill/killing blow and, when used, it should fire so fast to compete with ERLL for heat dissipation... So in the end I thought: why fit a very inefficient weapon when you want to punish those guys using that very same weapon?
    So naaa, don't join the dark side because you can fire at them iron cookies slugs
    Also:
    DON'T fight fire with fire
    DO destroy them with lazers
    DO Ace of Spades
  5. Excalibaard
    5,254
    Love the description.
    1 star because it should have the Funny tag.
    3 extra stars for it being well optimized and actually not even being bad in its intended role (if slow compared to most mechs of this playstyle).
    Total: 4/5.
  6. CarloArmato
    Ok, changed the tag to funny due to both description and overall build.
  7. Lorgot
    403
    72
    Idk, I felt that you could deal extra, if only a little damage, with some indirect damage and forget about it when you run out of ammo or have direct line of fire on them
    I just don’t like the idea of engines that aren’t optimized for the max amount of heatsinks
  8. Lorgot
    403
    72
    On the other hand forget what I said
    CarloArmato likes this.
  9. CarloArmato
    With DHS buff it could really be a thing... Did you try it? On paper is damn crazy
    675m x 1.15 (laser range quirk) x 1.15 (range skill bonus) x 1.115 (TC8 bonus) = 990 meters optimal range
  10. CarloArmato
    Steiner's fast sniper (TC8)
    Looks like a raven build under bad steroids... And officially 3xERLL 990 meters range
  11. Lorgot
    403
    72
    Would love to, but all my builds are theory crafted cause I don’t have the muns for it
  12. CarloArmato
    UPDATE: officially changed thread title and swapped the previous TC4 build with the more MEME TC8 version and changed description a little. And honestly, I'm gonna buy it for this build only.
  13. Lorgot
    403
    72
    Prefer tc7 because extra DH
  14. CarloArmato
    Yup, I've just tried it out without skills and it is damn hot. I'm trying it with LL instead of ERLL, but it should not be worth it due to lower range...
  15. Lorgot
    403
    72
    Only 3 alphas unfortunately
    Yeah, the whole point is the extreme range, otherwise the low mounts make it unviable for the builds purpose
