AS7-D-DC 'Ultra Smasher' (3xSRM4+A, 1xUAC20, 2xLL, ECM, LE350)
Thread in 'AS7-D-DC' started by Ether Dragan, Aug 16, 2017.
  1. Ether Dragan
    Ether Dragan Well-Known Member
    Hello,
    The new techs generation permit to update the Atlas very well.
    I propose you to test this beast. The profil is inspired by one of the classic build (STD 325, 3x SRM6+A, 1x AC20, 2 MLAS).
    But the new tech permit to upgrade the engine, upgrade the AC20 to a UAC20, and change the Medium Lasers to Large Lasers and max armour. The only things decrease is the SRM6 to 4 principaly for space reason (You have possibility to use SRM6 without Artemis for exactly same space and tons).
    At medium rang (300 to 600), use LLAS.
    At close rang, for a long brawl, use only SRM & UAC. If the UAC20 jammed, use LLAS carfully to avoid overheat.
    Group 1 : UAC20
    Group 2 : LLas
    Groupe 3 : SRM
  2. Excalibaard
    5,057
    1,108
    Made an alternative version of this with more focus on the SRMs than the lasers. This also freed up some more DHS space.
    Not sure which I prefer, as the reach of the LLs is good, but you have a fast engine and the heat it generated is already being taken up by other weapons.
