Casual AS7-D-DC "Midrange Mongo" (UAC10, UAC5, MRM40, ECM, Std330)
Thread in 'AS7-D-DC' started by renzor51, Apr 24, 2020.
  1. renzor51
    renzor51 Advanced Member
    393
    Wanted to come up with something bursty for midrange to take advantage of that ECM. A little underpowered for an Atlas, maybe? What do you think?
    Edit: I just tested it, and after killing the 8 testing ground mechs and firing the rest toward the sea, I found that (without ammo skill nodes), the ammo was very balanced. Ran out of MRM and UAC10 ammo with 6 rounds of UAC5 ammo left. ;) Looking forward to trying this out. Should be great at midrange.
  2. Shock
    873
    354
    You can probably drop at least one ton of MRM ammo. And 2 tons of UAC10 ammo is probably enough once you add skills.
    Maybe try something like this?
    Or this if you want to get your cooldowns synced better
  3. Excalibaard
    5,070
    1,108
    Not underpowered at all imo, double UACs with an HPPC, or a UAC20 with double MRMs are both effective builds on my banshee/cyclops. ECM is a nice addon.
    Not sure if I'd add more heat in the form of lasers as Shock suggested, but I would consider redistributing the ammo when you eventually do get the correct skills.
    Or, you could go full torso mode:
