Initial idea: SRM2s supporting big MRM launchers. Since SRM2s get ghost heat beyond 6, running 7 would not be beneficial. Wanting to use the CT HP (which is only really good for an SRM) means I decided on running 5 instead. Only having tonnage left for 2 big launchers at most, I figured the left arm could be stripped. In the end, this was the result. The MRMs are mounted low so can't be fired over hills, but are in the arm so you can trace targets more easily. You can also swap the mounting locations to gain the height advantage instead.
