Position, position, position.......when you move this slow you must keep situational awareness. That being said, let the match develop, pick your poison and start ripping things apart. You ARE the front-liner and when you push you will create panic and chaos. Not for the weak of heart. _
_ Similar build with endo and standard engine. I think that may work better. I dropped the LAMS for the third LPPC.
You also dropped a ton and a half of AC10 ammo, and you're running 12% hotter. I like to run hot, but not that hot.
You can get in four alpha's before worrying too much about heat. Then you still have the same 3xAC10s and 13 heat sinks.
I can get 9 Alpha's before having to worry about heat, have a ton and a half more ammo, and LAMS to help with the LRM's I'm seeing on all the maps.
