Thought as a decent light-kicker. _ Code: AX2D<:Z0|oBpN0DE7|OC|l^qN0BE7|OC|l^rH0AE7|@C|ZR|ZR|nR|n<2sH0EE7|@C|ZR|ZR|g<2tP0FE7uP0GE7vB0@E7w202020
To kill and hunt light heavy-lasers aren't that great: their longer duration implies that you have to hold your aim on the intended component for the whole duration of the laser burn, which almost impossible on heavy lasers. Plus their very low RoF means you are vulnerable to light brawler if you can't kill at the first strike. SRM ammo count is very high: you can easily drop some ton of ammo and fit bigger launchers. 3xMPL + 2xSSRM6 and 55% cooling efficiency seems a good balance... It's probably a bit too cold, but you should be able to play it with no skills and little issues. _
