ACW-PRIME "Ice Wolf" (4xSRM6+A, ECM, 3xJJ, LAP)
4 ratings
Thread in 'Arctic Wolf Omni Builds' started by xcgxcg, Oct 20, 2017.
  1. xcgxcg
    xcgxcg New Member
    So, this is my first time posting a build. Starting with something that seems pretty obvious. Hits ghost heat limit with plenty of ammo and some upgrades.
    EDIT: And already messed up title. Should be ACW-PRIME. Fixed.
    CarloArmato and Excalibaard like this.
  2. Excalibaard
    5,263
    Active probe is less useful if you already have ECM, because the ECm canceling doesn't work. You'll have to use the ECM counter mode instead. I think the .5t could be better spent on more ammo. Then again, 4 artemis launchers on a 40tonner is DEADLY.
    My slight alteration:
  3. The Verge
    Just a re-post of Excalibaards build.
  4. Excalibaard
    5,263
    @The Verge the link seems to work again in my post, but still odd..
  5. xcgxcg
    xcgxcg New Member
    The probe should still allow targeting non-ecm mechs faster right? Not a big deal, but I rarely want more ammo either.
  6. Excalibaard
    5,263
    it only speeds up target information, so you know which component to shoot. It does not improve targeting in other ways, only shut down mech detection and canceling ECM if you on't have ECM installed yourself.
    It's useful in the same way as a targeting computer, but more expensive and worse bonuses in general.
  7. SoLong
    SoLong Benefactor
    Good 4 scouting, LAP no need, but this personal prefer.
  8. waaaaaaaat
    waaaaaaaat Active Member
    I tried other variants (4 SRM6 plus 2 HSL; 2 SRM4 3 SRM6 1 HML) but this one is the best so far. The LAP is absolutely not worth the tonnage, bring more ammo. The Arctic Wolf in general can be a match-swinging mech if you do it right, so high alpha, surprise, and accuracy are key. The jump jets change the play too.
  9. ShooterMcGavin80
    519
    This is a solid, excellent build. I did it on the ACW-A though, as only one omnipod is a prime omnipod.
    No TC or CLAP/CAP necessary. More ammo or heatsink better.
  10. HKO2006
    HKO2006 Active Member
    83
    Modified from your version, used Prime arms for 5 armor.
    Dont forget the lower arm actuator too.
    ShooterMcGavin80 likes this.
  11. Evvo
    Evvo Advanced Member
    447
    Ran with full JJs instead of ECM
