WVR-7K 'Ursus' (1x LRM10+A, 1x ERLLas, 2x MLas, 2x SSRM2, BAP, 4x JJ, XL300)
Thread in 'WVR-7K' started by TheWatchman, Dec 18, 2013.
  1. TheWatchman
    TheWatchman Dispossessed
    A multi-purpose design here. With a good blend of fire-power, speed, armour and manoeuvrability, this would make a excellent Skirmisher.
  2. Aylek
    I am already designing some WVRs before they're finally available for CBills, and your build is quite similar to one I came to. I went a slightly different route, using the LPL + MLas combination in the 7Ks arm as well as a TAG for both the LRMs and the Streak lock-on, but otherwise this very comparable.
    After thinking a bit about your build here's what I don't like: The number of weapons in different locations. Those double MLas would usually go into the same group, but are mounted in different hardpoints using diverging reticles. ERLLas and MLas from the arm differ in range. LRMs and Streaks are the same... so your build basically needs 5 weapon groups for perfect play or you are gimping yourself in one or another way.
