Basically this is just a bigger version of my favorite panther build (the 9R with lpl, 3 mls, 250 engine, and 2 jjs). This version has a teeny bit less heat efficiency, but also has more armor and higher alpha. I'm a big fan of the laser boating arms because if your accuracy is good you can stick to a component and make your damage really count, plus you have the other arm for a shield, and paired with your high mobility you should have some really good survivability.
