_ Brother of WHM-6R "Pinpoint & crits" (2xPPC, 2xLBX10, XL300), this build makes the best use of the 10% energy range quirk to improve the fairly short LPL range, as well as the better damage over heat ratio (PPC would benefit of only -5% energy heat instead of -10% overall because there is no -5% PPC heat quirk like the WHM-6R). LBX10 range and LPL optimal range are fairly similar and should complement each other pretty decently.
WHM-6R has 2 quirks: -5% energy heat and -5% ppc heat. If you fit a PPC they will stack for an overall -10% heat, if you use any other energy weapon you will enjoy only a -5% heat bonus
