Combines the 3xLPL of a thunderbolt with the missile cooldown of a catapult _ 3xLPL for medium to short range pokes. 3xSSRM6 coupled with BAP and arms with lower arm actuators (no armlock FTW) to kill quickly (or fend off the fastest possible) those pesky lights / mediums that think messing with you is safe due to laser duration and torso mounted only weapons (2 ton of ammo are worth ~15 shots. Those shots should NOT be wasted on anything bigger than a 50 tonner included). Keep in mind SSRM6 are there to counter the latest "nascar-and-brawl-fast-mechs-only" fest. Your main weapons are the LPLs and SSRM6 are required for those moments when you can't either track your target properly or there is something you can kill quickly with an overwhelming alpha strike that won't miss unless it will hit a cover (also read: "alpha strike for those mechs that can't take damage at all, like any mech up to 45 tons included")
