WHM-6R "Warhammer 40(K)" (2xPPC, 2xAC10, XL255)
Thread in 'WHM-6R' started by VanBurenPhilips, Jan 24, 2016.
  1. VanBurenPhilips
    VanBurenPhilips Active Member
    75
    40 pinpoint alpha. This is for carefully placed shots, not for rapid fire! It does heat up, but not as bad as it looks on paper IMO, and you can fire the AC10s when hot.
    If you can score 1000 damage in it, I guess you can call it a Warhammer 40 K :)
  2. enileph
    Think You should have called it
    Warhammer 40k
    I mean, that is the only main game games workshop have, right? (Fuck Age of Sigma, it is a piece of shit that ruined warhammer fantasy)
    VanBurenPhilips likes this.
  3. VanBurenPhilips
    75
    Heh heh :)
    I don't know much about GW these days. Used to play WFRP as a kid (1980s), that's about it. But yes, the pun on WH40k was intended.
    Anyway, you're right, it's better with the k, so I've edited the title.
  4. POOTYTANGOSAUR
    178
    If you swap to lgpls, you can torso mount them and strip the arms. Allowing you to have higher leg and head armor and to carry an extra dhs. Range will go down a ways, but your sustained DPS, alpha, and heat generation in general improve. Also can go slightly faster.
  5. enileph
    Pulse laser is totally different from PPC though, and would be a different build. Look:
    Pulse Laser:
    PPC/Plasma type:
    These guys are probably medium mech, relatively speaking.
  6. dranozir
  7. CarloArmato
    1,726
    509
