Originally I had a torso mounted PPC setup on this mech, but always had major heat problems with it. So, I changed to this. With the LLs split two in each arm corner poking it great. At long range ridge trading, firing one side then the other sends 36 damage down range with no ghost heat. In a brawl you get two alphas before resorting to the 4 MLas or one set of LLs. I found this setup to be a great middle ground between High Alpha and Brawling. TL;DR: PROS: Good Alpha Good Corner Poker Good Brawler CONS: Runs Hot in Brawl Low Long Range Damage
