THIS IS A TEST TO DODGE THE BAD GUN BARREL DISTRIBUTION OF THE VICTOR. The idea of the MG is to force the AC5 barrels into a top-to-bottom lineup rather than the side-by-side lineup. If you want the MG to actually fire you may need to add a ton of ammo for it. I think single MG never gets any job done so I elect to ignore the ammo. Otherwise this is my "Spray and Spray" build with AC5 instead. More accurate, and with BAP, in case where you want to swap your SRM4 into SSRM2. If you don't use BAP then swap it in for engine size or some ammo/DHS. ***THE CURRENT RUNNING EDITION***
To hot build. Why an XL 380 ? With 375 you gain 1 Ton for heatsinks. The bap and machine gun are not usefull. And with a fast mech you dont have to use an AMS ( use the montain and building to cover ).
Unfortunately, this does not work, no matter the config. @dranozir, read the description for more information.
I had that problem too. Goot to to work a few times, but it move again sometimes, especially after patches or when you try to change ANYTHING. I begin to think that the success I had maybe a glitch on its own. Anyone else get that fix to work? REMEMBER: THE MAJOR POINT OF THIS BUILD IS TO TEST THIS FIX.
