Ignorant brawler, easy to use (but hard to be used properly with proper quick turning / timing), quite fast, good survivability thanks to both LE and the single JJ for quick turning / small jumps. Also, the -15% missile cooldown will pair up decently with the small pulse lasers, so you can actually do quick torso twist to shield any of your components during those ~2 seconds of cooldown Once skilled it's a beast, but be VERY careful when facing pinpoint builds with AC20, AC10 and/or Pulse lasers: you can't pinpoint as well as your opponent, so ALWAYS prioritise your defense / torso twist instead of aiming carefully, because you will always win the DPS / cool race, but you can't undo the damage dealt to a single component. That single JJ is your best friend for dodging / quick turning / disrupt the enemy aiming. Against those pinpoint build you have to fire 2 times: right before he shoots you AND while he is turning back to shot you again. You have very short cooldowns and you are really cool, so you just have to learn the timing and aiming. Do that and you can win the fight. If you wish to, you can swap half ton of LBX ammo for half ton of SRM ammo, but SRMs are the "worst" weapon due to spread and more than often you are not close enough to pinpoint the damage with those SRMs, so I'm fine with just 50-60 SRM missiles (~15 strikes) ALT: you can switch those LBXs for AC5, but they do have worse heat efficiency and, IMHO, due to very bad convergence it feels somewhat pointless to fit pinpoint weapons
