I like the stock Treb, even if it is thin-skinned and somewhat ineffective at skirmish range. This build drops its intended purpose and makes it a standard brawler. Bulwark and Sure Footing help it out in this role. **Adjustment: Drop 1ML in favor of 1 HS for one more round of fire before you overheat. Pros: Far more survivable than stock, almost 200 Alpha, SRM ammo for 16 rounds. Cons: No shield arm, no JJ, weak melee for a mid-range. This build shown using standard equipment. Using + or ++ will boost effectiveness, especially if you can drop a ML or two for heat sinks because of the increased damage.
