Casual TNS-5P "Brawlify" (1xLBX10, 3xSRM6+A, 3xML, ECM, LE300)
1 rating
Thread in 'TNS-5P' started by Excalibaard, Nov 17, 2017.
  1. Excalibaard
    4,531
    1,000
    Basically an orion with higher hardpoints and less survivability. Equip a DHS instead of 1t of SRM ammo if you have it skilled out with missile rack, or just because you die a lot before spending it all. It makes it 100% slot efficient, and helps out pretty well with the heat this build can generate.
  2. Sierra
    Sierra New Member
    Definitely another I need to try. I've been enjoying the LBX-10 on the 4P in a brawler configuration. This seems like a good evolution.
  3. Alloh_BR
    Alloh_BR Active Member
    good brawler... I prefer replacing SRM6 for MRM10, for range
