Theorycrafting the Carebear!
Thread in 'Kodiak' started by enileph, May 17, 2016.
  1. ReconSaint
    ReconSaint Star Lord
    184
    Run Hot or Die Bear
  2. Gneckes31
    A brawly KDK-4:
  3. cs_kami
    cs_kami Benefactor
    434
    try KDK-2 with Gauss 3t + 4xERLL, right side heavy, 2xERLL in right arm, 2xERLL in CT. left side is shield side. Works pretty well, the arm is big enough to act as a shield.
    On the KDK-4, 2xLPL, 2xUAC10 right side heavy. You can add some lasers to left side if you want, but id rather have more cooling/ammo
    Using the 1-2 missile hardpoints on the 1, 2 and 4 seems potentially pointless, because you are limiting then either you laser or ballistics potential. 4 can be an exception, but then you would have to downgrade the UAC10s to UAC5s or something.
  4. Spazamataz
    Spazamataz Junior Member
    WOOHOO,
    Kodiak section is now available!!
