TDR-9SE Serious Variant (2x PPC, 1x SRM4, 3x MPLas, 4x JJ, XL300)
Thread in 'TDR-9SE' started by Serious Table, Oct 20, 2013.
  1. Serious Table
    102
    This is a Mech with a good capability of dealing damage from multiple ranges, and really shines right around the 200-300m range. Do some good jump jet maneuvers as the enemy closes, placing 20 damage from the PPCs wherever they're best needed, then when they get in close, open up with the rest of the payload.
    WEAPON GROUPS:
    1) PPCs
    2) MPLas
    3) SRM 4
    4) PPCs on Chain
    5) MPLas on Chain
    Use this as a good knife-like support build. Support your teammates, and tear off limbs and side torsos that are exposed in order to disable your opponent and reduce incoming fire.
    Remember, you're using an XL; make ample use of cover to protect your Mech!
  2. LT Satisfactory
    LT Satisfactory Benefactor
    815
    61
    I've tried at least 6 builds for this mech and hated all of them. This one is well...least bad, haha. I'd personally change the armor values up a bit front/back but solid build.
  3. LT Satisfactory
    815
    61
    oh. and obligatory poptards suck post, but nothing else to do with this mech.
  4. schnaetz
    schnaetz Benefactor
    247
    I tested similar setups with 2PPC+SRM+X, PPCs in Side Torso or Arm:
    I always avoided those low-range MPLas, might give them a try on this mech though.
  5. Aylek
    Great minds thinking alike?? :phear:
  6. Serious Table
    102
    I used to think the same thing until I started running the Thunderbolts. I've found a new respect for Medium Pulse Lasers since, though.
  7. LT Satisfactory
    815
    61
    MPL love, really? I found I was running too hot shooting ppc's and then had to chainfire the mpl's to not overheat. I also found I was hardly using the srm since 20% of the the time it doesn't even register hits and doesn't do much dmg when it does for the weight. I dropped the srm and traded one mpl for ml and added ams/xl315. If I could have fit extra DHS, I would have, but you can't get the free slots. I think this is my final build of this mech for me:
    I wish I knew if JJ placement mattered at all - I'm never sure if it matters if they go ST or legs outside of if one appendage blows off easier.
