Hey everyone, guess what? IT'S FINALLY HERE! Yep, the D variant of the Timberwolf is finally available for C-Bills, which means I can now put together this upgraded version of my original "Perfectionist" build. The changes are small, but essentially, this build swaps a single SPL for an extra SRM6+A, providing a higher alpha as well as higher maximum and sustained DPS. This also changes the heat penalty values, as instead of a 2.4 penalty for firing the 7 cSPLasers, this updated version produces just 1.2 extra heat for firing all 4 cSRM6s. So overall, the benefit to heat and sustainability are pretty nice. I will provide three different links, each with its own focus. The first carries a full 5 tons of ammo, whereas the second drops one ton in favor of a TC1; and with the third, you are able to keep all 5 tons of ammo, as well as the TC1, by dropping a DHS instead. Which design you choose to run is entirely up to your personal preference and discretion. (Ammo) (TC1) (Ammo + TC1 - DHS)
goodlord, forgot about the omnipods being ready had to tweak it for me, those legs were frightfully skinny
4/5, Love this one. Oh, just remember I can vote for builds. Forgot that for some reason. This is my build I was using, before moving into some PPC build: Less dps but a bit more range.
dropped JJ in favour of one Heatsink and TC1 Edit: After the SPL nerf im missing the dmg, so going with MPL´s instead is the way i think Is it worth having TC1 with 3xMPL´s? otherwise i could go for another ton of Ammo New Build im Tinkering with So before 5xSPL had 30 Pinpoint Alpha after the nerf only 20, if im going with 3 MPL´s i have 22,5 dmg, more Range so u can shoot ur MPL´s when you are at Max Range with Missiles. Would u prefer to play with the old Build instead? The DMG Gain is not rly high but i like the Range. Should i drop the half ton of Ammo, TC1 and add a full ton of SRM Ammo and upping the Armor in the legs? or should i go with the Build from Enileph with 4 MPL´s so i would have the old 30 Pinpoint Alpha back After playing around with the 3 Builds im now at this one: +Armor +Ammo -TC1 19DHS with the Ammo Nodes in the Skilltree u have enough Ammo (720 SRM´s enough for 30 Salvo´s) and the Armor and Structure nodes make u a real Brawler Heat could be better but it´s fine sometimes u just have to retreat to cool down my Skilltree
3/5, This sadly took a huge hit from both the SPL nerf as well as the engine desync. It's still playable, but sadly not the beast it was back in the days.
