STK-5S "Sword" (2x LRM15, 2x ERL, 4x ML, 2x LRM5, 2x AMS, STD265)
Thread in 'STK-5S' started by Moonsword, Mar 14, 2013.
  1. Moonsword
    Moonsword Star Lord
    This is a build that I have spent some time working on and tweaking, I did it up like an LRM boat, with lasers to add a bit more punch.
    I also use the twin AMS to counter other LRM boats.
    I did have 1080 LRM ammo, but I ditched 1 ton of it for extra AMS ammo because I found it was chewing it up very quickly.
  2. Mythweaver
    Mythweaver Advanced Member
    400
    This looks quite dangerous assuming you are using Scouts to TAG for you. Do you not burn through LRM's at a crazy rate? You may also want to consider exchanging one Med. Laser for a TAG to make you more self sufficient.
    I like the build, these are just suggestions.
    Mythweaver
  3. Moonsword
    Moonsword Star Lord
    So far, having played several rounds with this build, I have not run out of LRM ammo, I also use my lasers if I have line of sight, need to watch my heat when I do.
    As for swapping one of the meds with a tag, I like that idea and I will give it a shot.
  4. Svarris
    Svarris New Member
    This build has apparently been lurking here for quite some time. This is a stupendous build and an absolute blast. Averaging around 600DMG per match. Definitely an extremely good build. "Backup" weapons are perfectly fine for engaging normal targets with.
    10/10
