I can't find this build anywhere on here so I hope i'm not copying anyone elses build. This works really good as missile boating but packs a punch with 4ml up close if anything damaged makes its way to you, tag gives a ton of assists and makes those ecms get mad. Fire all the lrms at once unless you are getting really hot over 50 heat, then just hold down chainfire and you stay pretty cool. Obviously avoid direct combat if possible but make sure to assist your team and not just sit in back and camp, tag is a huge assist to your entire team I stay within 600m or so. Weapon groups are 1:tag 2:4xml linked 3:2xlrm15 linked 4:2xlrm10 linked 5:2xlrm15+2xlrm10 chained 6:2xlrm15+2xlrm10 linked Proof
I've been running a very similar build for ages, except mine has a standard engine. It's amazingly effective thanks to the favourable tube layout; assaults just melt under the barrage of focused LRM fire! I really hope that aspect of this mech won't be changed when they finally do the Stalker geometry pass. Run it with the LRM15 cooldown module and the LRM15s synch up nicely with the LRM10s.
