STK-3Fb "Ghostbuster" (3xLPL, 3xMPL, ECM, AMS, STD300)
1 rating
Thread in 'STK-3Fb' started by Excalibaard, Apr 23, 2017.
  1. Excalibaard
    4,345
    956
    219
    As you can deduct from the title, a build without ghost heats! Fire away! (you can swap AMS + armor for BAP for faster target info gathering)
    Essentially the same build can be done on a black knight, but the stalker has higher hardpoints and can do it with a standard engine and ECM :)
  2. ShiverMeRivets
    ShiverMeRivets Active Member
    92
    I bought the STK-3FB thinking about this build, but I use a different, asymmetrical arrangement: 3 LPL on the right side, 3 MPL on the left. This way I can right-poke with the LPLs, and try to shield more with the left.
    This plays very nice, and the 3FB avoids some of the other Stalkers pitafalls with 85 deg yaw (vs. 60) and boosted maneuverability. The fact that this mech requires 0 (!) quirks just says how good it is. OK, the boosted accel/deccel yaw/turn rates are like hidden quirks.
    P.S.,
    Regarding the original build, I remember something about BAP not countering enemy ACM when installed on ACM mechs. AMS with 1/2 ton ammo is not much, so I threw in a TC1 instead.
  3. Lorgot
    Lorgot Well-Known Member
    For more umph if ever needed and better range synergy
