St. Ives' Blues "White Death" (2x ERLL, 2x SRM4, 1x ML, 1x JJ, XL250)
Thread in 'St. Ives' Blues' started by enileph, Aug 20, 2014.
  1. enileph
    A logical choice.
    Feel free to downgrade to LL for better Heat.
    Don't like the ML? swap it out for some JJ.
    Another option would be SRM6.
    or even SRM6+A
  2. skidog2k3
    skidog2k3 Dispossessed
    Seems like the obvious choice for this varient.
  3. Remarius
    Not so sure on that 1 JJ seemed pointless on the new mech factory map. Whereas 4 gave you a huge level of capability to ambush.
  4. Auriga
    Auriga MechSpecs Addict
    599
    Quite similar to the config i feel like the optimal for this mech
    The 2 armour points in the head should works cause now everything that hits a St Ives in the head ends, magically, hitting the CT. Later u may consider to increase it.
  5. Remarius
    Yeah after the semi-failure that was my LPL version I ended up with a similar version - swapping the head medium laser for 2 JJ's. Planning on going back to the LPL one but while the Hood is bugged close in is a death trap.
