SNS-A 'Downrange' (2xcUAC10, 1xcERPPC) set of 8
Thread in 'Sun Spider Omni Builds' started by ShooterMcGavin80, Jan 31, 2020.
  1. ShooterMcGavin80
    421
    Omnipod set of 8 build on the SNS-A gives you:
    Relatively easy to deliver 55 point alpha, which ideally can be followed up with another 40 point double tap before you retreat back to cover. Heavies and Assaults are your best targets, slippery little mediums and lights aren't very good targets for UAC's unless you can catch them momentarily stopped.
    https://kitlaan.gitlab.io/mwoskill/...031081cff7f0000e86f770f000080a22119#s=Weapons
    If you want to put this on your Vanguard, it also works there with set-of-8 quirks:
  2. ShooterMcGavin80
    421
    Post skill up report:
    Pretty solid. Not 'meta', but good. You are fragile and need to play the careful peak game instead of trying to go toe to toe with anybody. But if you can get good trades, the damage will rack up. Avoid pushing, and avoid getting pushed. This requires good map positioning and team mate support.
    Final skills:
    https://kitlaan.gitlab.io/mwoskill/...031081cff7f0000e86f770f0000808f0701#s=Weapons
    2 arty's, 2 UAV's. UAV's are optional, could switch to cool shots.
    Simple fire groups:
    Right click: right arm ERPPC
    Left click: both UAC's.
  3. ShooterMcGavin80
    421
    Bara gave a good showcase of the build on the Vanguard:
