SHD-2D Victor'sLittleBrother (1x Gauss, 1x ERPPC, 1x JJ, XL300)
Thread in 'SHD-2D' started by Motörhead, Jun 27, 2014.
  1. Motörhead
    Decently fast and jumpy. Nice armor other the the right arm. Runs cool usually. Enough ammo for all the match.
    I find all the weapons on the same side pretty much needed, with all the firepower on the battlefield that clan mechs introduced, you can afford to expose for very little time with an IS medium, let alone one with XL engine and gauss, much less then you could before, and you need to pick fast shots using the weapon convergence, so even if the 5M is able to copy the build on the paper, on the field it can't be nearly as effective.
    25 Pinpoint Damage up to 660m.Pretty good numbers for an IS medium.
  2. SuicidalBaby
    SuicidalBaby Well-Known Member
    only need 1 jj
    lose the crap
    crit pad
    up the engine to something reasonable
    Motörhead likes this.
  3. Motörhead
    Edited after tests, for an XL300 version.
    With gauss and ERPPC cooldown modules now this mech is a really good sniper.
    If one doesn't mind having the gauss not on the same side of the ppc, this can be done in the H, to gain a module slot, fact is, ppc arm can come handy to shield the gauss too, the H can't do that.
