_ 3xLBX10 featuring a whopping -15% cooldown quirk. 3xERSL features an additional 9.9 damage for those situations when you are still very cool and/or you need all the alpha strike you can get. This build is pretty slow, but packs a tremendous and sustained punch if left unchecked. Stick with your bigger brothers (which hopefully will attract most of the attention) and keep on steam rolling anything in your path. Soloing with this mech is not recommended: two alpha strikes on the same side torso will force you back to the mechlab. Skill wise: max cooldown, max ammo, max laser duration, max LBX spread, max armor, max structure, max seismic sensor (which implies max targeting info and range for fast data acquisition), 1 additional consumable. https://kitlaan.gitlab.io/mwoskill/...f0000000000000000000050a7dff6000000#s=Weapons ALT: drop 1xERSL in favor of a faster XL265 (+1.5 km/h). You can even drop even more armor (~16 points) to fit both 3xERSL and an XL265, but I think you are risking too much with such few armor). _
