Quirks came out, and this one has an interesting clan LPL HSL +2. Which means you can fire 4xLPL without feeling any ghost heat. Maybe: _ Also, if this is like the IS Rifleman, there could be a weird slot thing where you have to 'push' up your LPL's into the higher hardpoints with another 'dummy' weapon. This build is just too hot I think to also use ERML's, so I'll be just trying ERuL: _ But if it turns out the heat can be taken, ERML's would be a better supplement: _ <edit - changed build links to get the order right to place the LPL's in the higher arm hardpoints>
Very small adjustment: 2nd hardpoint on each arm is the lowest and the 3rd is the highest. Simply occupy the 2nd hardpoints with a ER micro laser and the 2nd LPL on each arm will be the highest. Now it will become way better at poking. _
I've warmed up to it and its not great, but it isn't terrible and can give you the occasional excellent carry game, so long as you are reaaaally careful and sneaky about your team positioning and exposure. Final build and skills: _ https://kitlaan.gitlab.io/mwoskill/...062101cf37f0000e86f770f000080a22119#s=Weapons
