This is a straight copy from my 9R Focused Wub version but not as good a fit to the quirks so I'm running it as a test at the moment. If you're not brawling its worse than the dual ER PPC version. If you're fighting lights its far better. Additional Structure Right Arm 12 Additional Structure L/R Leg 6 ER-PPC Cooldown 25% Energy Weapon Cooldown 12.5% ER-PPC Heat Generation -25% Energy Weapon Heat Generation -12.5% ER-PPC Velocity 40% Missile Weapon Cooldown 15% Missile Weapon Range 15% Acceleration 15% Deceleration 15% Turn Rate 10% Either way it has nice focused firepower at a decent range and heat usage on a small humanoid profile. As before hit and run. I'm getting 1-3 kills in almost every battle so seems nicely reliable. Not bothering to remake these as literally identical to my 9R version. XL 250 version with 1 jump jet.
Been running with XL 245. I drop 6 armor from the head but get full shield arm on the left side. Running much better than the 2 ER-PPC build. You don't need Artemis, but it comes that way.
ERPPC version was so hot I had time to think, decided I'd try the LPLas straight swap, way better. First round:
5/5, The meta panther build for quick play: very good pinpoint, decent range and very good heat efficiency, but lasers on the arms are low... Still, it's one of the best builds you can make with this chassis, and the dual SNPPC build is too hot for quickplay (dual SNPPC it's better used for Solaris and 1v1) Quirk update: Spoiler Energy Cooldown− 10 % Energy Heat− 20 % Missile Cooldown− 10 % Missile Velocity+ 10 % Ppc Velocity+ 20 % Base Armor (CT)+ 12 Base Armor (LA)+ 16 Base Armor (LL)+ 12 Base Armor (LT)+ 12 Base Armor (RA)+ 24 Base Armor (RL)+ 12 Base Armor (RT)+ 12
